Yes. KBS Bed Renu is a spray can bed liner made for bumpers on cars, trucks and off-road vehicles, including Jeep bumpers. It cures to a textured, UV stable black finish that will not crack, bubble or peel, and will not chalk, fade or discolor in the sun, with no spray gun, compressor or mixing.
KBS Bed Renu on Bumpers: Quick Facts
Coverage: up to 30 sq. ft. per 15 oz. can
Recoat: 1 to 2 hours, dry to the touch
Full cure: usually within 48 hours
Spray at: 50 to 90F, 70% humidity or lower
Prime first on bare surfaces. Plastic bumpers need Fusion FPP under KBS Bed Renu. Metal bumpers worn to bare metal need the KBS 3-Step Rust Prevention System first. Both steps are below.
Steel Bumpers
If a metal bumper still has sound paint, clean it with KBS Klean and let it dry. Avoid solvent-based cleaners, which leave invisible residues that can affect adhesion. If the bumper is down to bare metal, use the KBS 3-Step Rust Prevention System: clean with KBS Klean, etch with RustBlast, then prime and seal with RustSeal. Spray KBS Bed Renu directly over the RustSeal when it is between 3 and 8 hours old, with no other prep. Past 8 hours, let the RustSeal cure a full 24 hours and scuff it with 320 grit before spraying. That base gives the ultimate longest lasting finish.
Plastic Bumpers
KBS Bed Renu goes on plastic bumpers over Fusion FPP. The Fusion FPP directions call for sanding the plastic lightly with fine sandpaper or steel wool for maximum adhesion. Fusion FPP is dry to the touch in 10 minutes and ready for KBS Bed Renu in 30 minutes.
Spraying the Bumper
Spray between 50F and 90F in 70% humidity or lower. Shake the can for at least one minute after the mixing ball rattles, and shake again for about 10 seconds every 1 to 2 minutes while spraying. Hold the can 8 to 10 inches from the bumper, press the valve all the way down, move back and forth releasing the sprayhead after each stroke, and overlap each stroke. Apply one or two thin covering coats, recoating once the previous coat is dry to the touch. Full steps are in the KBS Bed Renu directions.
Coating a Whole Bed or a Big Job?
One 15 oz. can of KBS Bed Renu covers up to 30 square feet, and a 3-pack covers up to 90. For a full truck bed or a larger area, KBS Bed Liner comes by the gallon, covers up to 250 square feet at 2 coats, and rolls, brushes or sprays on.
Frequently Asked Questions: KBS Bed Renu on Jeep Bumpers
Yes. KBS Bed Renu is a spray can bed liner made for bumpers on cars, trucks and off-road vehicles, including Jeep bumpers. It cures to a textured, UV stable black finish that will not crack, bubble or peel, and will not chalk, fade or discolor in the sun. Prime bare plastic bumpers with Fusion FPP first, and prep bare metal bumpers with the KBS 3-Step Rust Prevention System.
KBS Bed Renu goes on plastic bumpers over Fusion FPP. Sand the plastic lightly with fine sandpaper or steel wool, apply Fusion FPP, and spray KBS Bed Renu once the Fusion FPP is ready to topcoat, 30 minutes after application.
Use the KBS 3-Step Rust Prevention System. Clean with KBS Klean, etch with RustBlast, then prime and seal with RustSeal. Spray KBS Bed Renu directly over the RustSeal when it is between 3 and 8 hours old, with no other prep. Past 8 hours, let the RustSeal cure a full 24 hours and scuff it with 320 grit first. That base gives the longest lasting finish.
Apply one or two thin covering coats. Hold the can 8 to 10 inches away and overlap each stroke. Runs or sags mean the coat is too heavy or the can is too close.
KBS Bed Renu is dry to the touch and ready to recoat in 1 to 2 hours, depending on humidity. Apply each coat within 24 hours of the previous coat curing. Full cure is usually reached within 48 hours.
Yes. KBS Bed Renu is made for fender flares and running boards as well as bumpers and worn truck bedliner, with a textured, UV stable finish that is easy to clean.
Still have questions about KBS Bed Renu? Contact us for help.
