Yes, metallic colors of KBS MAXX can be brushed. Brush out the coat, let it set for a few minutes, then lightly brush the surface again in one direction. That second light pass helps float the metallic pigments to the surface for an even sparkle. Spraying still gives the most uniform metallic finish, so use this technique when spraying is not an option.
The Two-Pass Brush Technique
- Mix the KBS MAXX Base thoroughly with a mechanical mixer, then add MAXX Activator at 3 parts Base to 1 part Activator. See how to mix KBS MAXX for the full process.
- Brush the area out with a poly bristle brush and move on. Do not brush the same spot over and over.
- Let the coat set for a few minutes.
- Lightly brush the surface again, with every stroke running in the same direction. This is the pass that floats the metallic pigments up.
- Recoat any time from 30 minutes to 3 days after the first coat, with no scuffing needed.
Why not keep brushing until it looks right? Reworking an area forces the solvents out and speeds up the cure, so the brush marks lose their chance to flow out. KBS MAXX is designed to level on its own. Lay it down, make the one light pass, and leave it.
If You Can Spray, Spray
Spraying is still the best way to get a uniform metallic finish. The KBS MAXX directions give a specific technique for single stage metallics like KBS MAXX: spray a full covering coat, wait a minute or two but not long enough for it to tack over, then apply a mist coat while holding the gun farther from the surface and pulling the trigger only 50 to 75 percent.
For HVLP, the directions call for 15 to 20 psi air pressure and a 1.0 to 1.5mm tip, such as the KBS HVLP Spray Gun with the 1.4mm tip. KBS MAXX is pre-thinned and ready to spray as mixed. Our Paint Spraying Guidelines cover gun setup in more detail.
KBS MAXX Metallic Colors
The current metallic colors are Gunmetal Metallic, Silver Metallic, Silver Metallic Satin, Relic Metallic Blue in gloss and matte, and Silverpine Green Metallic. To see a color in your own light before you order, request a free color sample.
Frequently Asked Questions: Brushing Metallic KBS MAXX
Still have questions about KBS MAXX? Contact us for help.
